How to integrate Complianz for WordPress CMP with Matomo
Complianz – GDPR/CCPA Cookie Consent is a WordPress plugin that supports third party blocking, auto-detection/configuration of plugins and handles consent requirements for different countries based on visitor geolocation. The consent manager includes a step-by-step setup wizard that makes configuration quick and easy and it offers built-in support for Matomo and Matomo Tag Manager (MTM). The Tag Manager method is covered in a separate guide.
This guide focuses on three integration methods using Matomo.
Before you start
Install the Matomo plugin
Matomo is compatible with the Connect Matomo plugin and Matomo for WordPress plugin.
- Open WordPress to install and activate the preferred Matomo plugin.
- For the Connect Matomo (WP-Matomo) plugin:
- Click on the plugin’s Settings and go to the Enable Tracking tab.
- From the Add tracking code drop-down, choose Disabled.
- Save the changes.
- For the Matomo for WordPress plugin:
- Click on the Matomo Analytics menu > Settings.
- For the Tracking mode, choose Disabled.
- Save the changes.
Install the Complianz GDPR/CCPA Cookie Consent plugin
- Open WordPress > Plugins > Add Plugin > search for Complianz and install; OR
- Download the Complianz – GDPR/CCPA Cookie Consent plugin.
- Open WordPress > Plugins > Add Plugin > Upload Plugin and select the plugin you downloaded from WordPress.
- Once installed, click Activate.
The tracking configuration for each consent method is described below.
Configure Complianz consent manager
- Once the Complianz GDPR/CCPA Cookie Consent plugin is installed, navigate to WordPress > Plugins > Installed Plugins.
- Ensure the Complianz plugin is activated and click Settings.
- From the Complianz Dashboard, open the Wizard tab (or click the Continue Wizard button) to go through the configuration steps.
- Follow each step and configure according to your privacy laws and requirements.
- In the section, Consent > Statistics, select the following options:
- Do you compile statistics of this website? – choose Yes, with Matomo.
- Do you want to use cookieless tracking with Matomo? – choose No. This prevents any tracking before consent is granted.
- Continue to the next step, Statistics Configuration and select the following option:
- Do you want Complianz to add Matomo to your website? – choose Yes.
- Provide your Matomo instance URL and site ID (for Matomo Cloud or On-Premise). If you are using the Matomo for WordPress plugin, then the URL for your Matomo installation will be:
your-domain.com/wp-content/plugins/matomo/app
- Continue through the wizard to the Cookie descriptions and Service descriptions steps, where you should see auto-configured entries for Matomo.
Remove/disable Matomo tracking
Remove or disable any existing Matomo tracking code from your WordPress site.
- If you manually added the tracking code to your WordPress site, it must be removed.
- If you are using the Matomo for WordPress plugin or the WP-Matomo (Connect Matomo) plugin, go to Installed Plugins and open the plugin settings.
- For the Enable Tracking option, ensure tracking is disabled.
- Save your settings.
- Do not deactivate the Matomo plugin.
Validate the integration
- In your Matomo instance, select the Visits in Real-time report, and check that no tracking requests are sent.
- Perform some test actions and check your activity was not recorded in the Visits in Real-time report.
Configure the consent manager
- Perform test actions on your website and view the Visits in Real-time report to verify tracking requests are sent to Matomo.
mtm_consent_removedcookie is set. - Perform test actions on your website and view the Visits in Real-time report to ensure no tracking requests are sent to Matomo after opting out.
- Perform test actions on your website and view the Visits in Real-time report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
- Once the Complianz GDPR/CCPA Cookie Consent plugin is installed, a wizard may appear to take you through configuration steps or you can navigate to WordPress > Plugins > Installed Plugins.
- Do you want to use cookieless tracking with Matomo? – choose Yes. This allows cookieless tracking before cookie consent is granted.
your-domain.com/wp-content/plugins/matomo/app.
- In the Visits in Real-time report, check that tracking requests are still sent.
