How to integrate Didomi CMP with Matomo
Didomi consent manager integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on three consent methods using the Matomo tracking code.
Before you start
Didomi offers extensive configuration options for advanced consent management setups such as enabling IAB Transparency and Consent Framework (TCF v2.2), creating multiple vendors, purposes, and consent notices for different regions. The example provided in this guide covers a general purpose-based integration where consent for analytics tracking is shared with Matomo.
If your tracking setup involves advanced configurations, refer to the official Didomi documentation for framework-specific implementation details and API usage.
Configure Didomi consent manager
- Set up your Didomi account.
- Define a Vendor (for Matomo) and the applicable Purposes.
- For Matomo, select Analytics (Purpose ID:
analytics_tracking). Read the Didomi documentation on managing vendors and purposes. - Purposes must be assigned to the Opt-in or Opt-out purposes (according to the consent method used).
- Take note of the Vendor ID and Purpose ID.
- Complete the necessary steps to configure your Consent Notice in line with the consent method used and the legal requirements that apply to your website.
- After publishing the notice, copy your Didomi SDK snippet and paste it as the first tag within the
<head>section of the web pages you are tracking. This example uses the default Didomi domain to load the SDK.
- The Consent choices opening link (shown as step 4 above) is included in the consent handling script below.
- If you do not have the tracking code installed yet, go to Matomo > Administration
> Websites > Tracking Code and select the website you want to track. - Copy the tracking code shown in the code box and paste into a text editor.
- Insert the line
_paq.push(['requireConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code inside the
<head>tag on all the website pages you are tracking. - If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
_paq.push(['trackPageView']);
(function() {
var u="//matomo/";
</script>
<!-- End Matomo Code -->
Install the Matomo consent handling script
The integration relies on the Didomi SDK to collect and store consent for your configured vendor and purposes, and communicate user consent to Matomo. This script listens for Analytics consent events and enables or disables Matomo tracking depending on the user’s choice..
<script>
// --- REPLACE YOUR_VENDOR_ID` with the Vendor ID created in Didomi---
var VENDOR_CANDIDATES = ['YOUR_VENDOR_ID'];
var PURPOSE_CANDIDATES = ['analytics_tracking'];
function idsFrom(x){ return Array.isArray(x) ? x.map(v=>v.id) : Object.keys(x||{}); }
function vendorGranted() {
try {
var vRaw = Didomi.getVendors && Didomi.getVendors();
var vendorIds = idsFrom(vRaw);
var existing = VENDOR_CANDIDATES.filter(id => vendorIds.includes(id));
if (!existing.length) return true; // no Matomo vendor in notice → don’t block on vendor
return existing.some(id => !!Didomi.getUserConsentStatusForVendor(id));
} catch(e){ return true; }
function purposeGranted() {
try {
var pRaw = Didomi.getPurposes && Didomi.getPurposes();
var purposeIds = idsFrom(pRaw);
var existing = PURPOSE_CANDIDATES.filter(id => purposeIds.includes(id));
if (!existing.length) return true; // no analytics purpose in notice - do not block on purpose
return existing.some(id => !!Didomi.getUserConsentStatusForPurpose(id));
function isGranted(){
var v = vendorGranted(), p = purposeGranted();
console.log('[Didomi] vendorOK=%s purposeOK=%s', v, p);
return v && p;
function onGrant(){
console.log('[Glue] consent granted then enable Matomo');
function onWithdraw(){ console.log('[Glue] consent not granted then disable Matomo');
_paq.push(['forgetConsentGiven']); }
function apply(){ isGranted() ? onGrant() : onWithdraw(); }
// Reliable ready hooks (SDK must be before this block)
window.didomiOnReady = window.didomiOnReady || [];
window.didomiOnReady.push(function(){ console.log('[Hook] didomiOnReady'); apply(); });
document.addEventListener('didomi-consent-changed', function(){ console.log('[Event] didomi-consent-changed'); setTimeout(apply,0); });
document.addEventListener('didomi-ready', function(){ console.log('[Event] didomi-ready'); apply(); });
</script>
<!-- User can review and reset consent preferences -->
<button id="open-preferences">Open preferences</button>
<button id="reset-consent">Reset consent</button>
<script>
document.getElementById('open-preferences').onclick = function () {
if (window.Didomi?.preferences?.show) Didomi.preferences.show();
document.getElementById('reset-consent').onclick = function () {
if (window.Didomi?.reset) { Didomi.reset(); location.reload(); }
</script>
Validate the integration
- Open your website and use the Consent Notice to decline tracking consent.
- If using cookie-based tracking, open the browser’s developer tools (press F12 or right click > Inspect) and view the Application (or Storage) > Cookies tab to confirm cookies were set.
- Revoke/reset consent and confirm that Matomo tracking stops and cookies are deleted from the browser.
This simple test confirms that the integration correctly respects regional privacy requirements and only activates tracking after consent is granted. If you are experiencing errors or issues with the integration test, read the Troubleshooting section below.
Configure the Consent Manager
- Configure your CMP to either load Matomo Analytics cookies and start tracking without prior consent. Didomi offers a CNIL (France) configuration for the GDPR regulation. Edit Consent Notice > Customization > Specific settings:
- Perform test actions on your website and view the Visitors > Real-time report to verify tracking requests are sent to Matomo.
- Open the browser’s developer tools (press F12 or right click > Inspect) and view the Application or Storage > Cookies tab to verify that the
mtm_consent_removedcookie is set. - Perform test actions on your website and view the Real-time report to ensure no tracking requests are sent to Matomo after opting out.
- Change the settings to opt back in and resume tracking to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
- Insert the line
_paq.push(['requireCookieConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code inside the
<!-- Matomo -->
<script>
(function() {
var u="//matomo/";
</script>
Install the Matomo cookie consent handling script
The integration relies on the Didomi SDK to collect and store consent for your configured vendor and purposes, and communicate user consent to Matomo. Cookieless tracking is active by default. This script listens for Analytics consent events and enables cookies or disables Matomo tracking depending on the user’s choice.
<script>
try {
try {
return v && p;
function onGrant(){
_paq.push(['deleteCookies']); // Ensures Matomo tracking cookies are removed when consent is withdrawn
</script>
<script>
</script>
- Open the browser’s developer tools (press F12 or right click > Inspect) and view the Application (or Storage) > Cookies tab to confirm cookies were set.
This simple test confirms that the integration correctly respects regional privacy requirements and only uses cookies after consent is granted. If you are experiencing errors or issues with the integration test, read the Troubleshooting section below.
Troubleshooting
If you are having tracking issues or the consent is not being managed correctly, follow these steps to identify and resolve the problem:
1. Load order matters
Place the Didomi SDK snippet as close as possible to the top of the <head> tag. The SDK must load before any vendor scripts to ensure that Didomi is fully initialised before Matomo checks for consent. Refer to the `official Didomi instructions for loading the SDK.
2. Check the Matomo tracking code
Your Matomo tracking code must include the requireConsent or requireCookieConsent method before any other tracking commands. This ensures that Matomo does not track or set cookies until the user explicitly grants consent through the Didomi Consent Notice. Read more about Implementing tracking or cookie consent with the Matomo JavaScript Tracking Client.
3. Confirm correct Vendor and Purpose ID
The Didomi Consent Notice must include the exact vendor ID and purpose ID that your script checks for. For example, if your Matomo vendor ID is matomo-AbCdE and your analytics purpose ID is analytics_tracking, those same values must be used in your script.
If the IDs in the consent handling script do not match what is configured in the Didomi Console, Didomi will always block Matomo tracking. If you make any changes to your Consent Notice, republish, so the latest version is live.
Note: The Didomi SDK snippet references your Didomi Public API Key and the Consent Notice ID. Ensure these are the correct values included in the SDK.
4. Review security policy
If you are loading the SDK from the default Didomi domain, the following domains must be whitelisted in your site’s Content Security Policy:
https://sdk.privacy-center.org/
https://api.privacy-center.org/
If either is missing, the SDK will fail to load or communicate with Didomi’s servers and failed network requests or console messages might be displayed such as loader.js failed to load. When testing, disable strict tracking protection or ad-blockers as some browsers may block sdk.privacy-center.org by default.
