How to integrate GetTerms CMP with Matomo
CMP integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on two integration methods using the Matomo tracking code.
Before you start
- Create your GetTerms account.
- Complete the necessary steps to configure your cookie banner in line with the consent method used and the legal requirements that apply to your website.
- Ensure your Matomo JavaScript code snippet is added to the web pages you want to track and placed before the closing head
</head>tag.
Install GetTerms consent manager
- To install the consent manager initialisation script, copy the script from your GetTerms account in Cookie Banner > Installation.
- Add the CMP script to the web pages you want to track. This should be placed as the first script below the opening
<head>tag.
Note about consent categories in GetTerms
GetTerms displays cookies using user-friendly category names in the banner (for example, Performance), but the actual consent values are stored in the cookie_preferences object in localStorage. These stored values use predefined category keys such as: Essential Cookies, Functional, Marketing, Analytics, and Unclassified.
For integrations, always use the stored consent object. For example, even if Matomo cookies appear under the Performance category in the banner, the corresponding consent signal may be stored under:
consent.cookie_preferences['Analytics'] === true
You can inspect the stored consent object in your implementation to confirm which category controls your tags:
console.log(JSON.parse(localStorage.getItem('getterms_cookie_consent')));
This ensures that tracking behaviour matches the actual consent signal used by GetTerms.
- If you do not have the tracking code installed yet, go to Administration
> Websites > Tracking Code and select the website you want to track. - Copy the tracking code shown in the code box and paste into a text editor.
- Insert the line
_paq.push(['requireConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code before the
</head>tag on all the website pages you are tracking. - If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
_paq.push(['trackPageView']);
(function() {
var u="//matomo/";
</script>
<!-- End Matomo Code -->
Install the Matomo consent handling script
The following script listens for consent updates and enables/disables tracking when consent is granted/denied. Add the consent handling script before the closing tag on all website pages that contain the Matomo tracking code.
(function () {
var MAX_WAIT = 40;
var waitCount = 0;
function getConsentFromStorage() {
try {
var stored = localStorage.getItem('getterms_cookie_consent');
return stored ? JSON.parse(stored) : {};
} catch (e) {
return {};
function hasAnalyticsConsent(consent) {
return !!(
consent &&
consent.cookie_preferences &&
function deleteMatomoCookies() {
var cookies = document.cookie.split(";");
cookies.forEach(function (cookie) {
var name = cookie.split("=")[0].trim();
if (
name.indexOf('_pk_') === 0 ||
name === 'mtm_consent' ||
name === 'mtm_consent_removed'
var domains = [
location.hostname,
'.' + location.hostname
domains.forEach(function (domain) {
document.cookie = name + "=;expires=Thu, 01 Jan 1970 00:00:00 UTC;path=/;domain=" + domain + ";";
// fallback (no domain)
document.cookie = name + "=;expires=Thu, 01 Jan 1970 00:00:00 UTC;path=/;";
function applyConsent(consent) {
if (hasAnalyticsConsent(consent)) {
} else {
deleteMatomoCookies();
function waitForMatomo() {
if (typeof _paq === 'undefined') {
if (waitCount < MAX_WAIT) {
waitCount++;
return setTimeout(waitForMatomo, 250);
return;
// Apply stored consent on initial load
applyConsent(getConsentFromStorage());
// Listen for GetTerms updates
document.addEventListener('getterms-consent-updated', function (event) {
applyConsent(event.detail || {});
// Start after DOM is ready
document.addEventListener('DOMContentLoaded', waitForMatomo);
Test the integration
- GetTerms allows you to optionally block page interaction before consent preferences are set.
- Open your website and use the consent manager widget to decline tracking consent.
- In your Matomo instance, open the Visitors > Real-time report, and check that no tracking occurred.
- Next, grant consent and verify that tracking started.
- For cookie-based tracking, open the browser’s developer tools and view Application or Storage > Cookies tab to confirm cookies were set.
- Revoke consent and confirm the Matomo cookies are deleted from the browser.
Configure the Consent Manager
- Perform test actions on your website and view the Visits in Real-time report to verify tracking requests are sent to Matomo.
mtm_consent_removedcookie is set. - Perform test actions on your website and view Visits in Real-time report to ensure no tracking requests are sent to Matomo after opting out.
- Perform test actions on your website and view the Visits in Real-time report to ensure tracking requests are sent to Matomo.
